Message 21 of 48
Re: HD channels
@Seany10hats
I'm surprised that your Samsung qn95a TV hasn't got Freeview as the specs show it's got 2 tuners for Freeview reception and quite frankly all TVs these days have either Freeview/FreeviewPlay and/or Freesat tuners.
Message 22 of 48
Re: HD channels
I was surprised too
Message 23 of 48
Re: HD channels
@Seany10hats
Everything says that it can receive TV channels over the aerial (terrestrial) if connected so I can't understand the issue.
Message 24 of 48
Re: HD channels
@Seany10hatswrote:
I’ve got a Samsung qn95a and it doesn’t have freeview or freesat or freeview app availability.
Your TV has tuners for both Freeview HD and satellite (DVB-T2/S2 is shown on the specifications) - it may not be certified for Freeview Play but will certainly display the Freeview channels perfectly fine - just connect it to an aerial!
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 25 of 48
Re: HD channels
If you Google “does Samsung qn95a have freeview?” The first thing that comes up is No
Message 26 of 48
Re: HD channels
Yes it can receive channels. On some rubbish called Samsung plusTV. Not freeview uk channels. You just get about 45 channels you’ve never heard of. All showing stuff like americas next top model
Message 27 of 48
Re: HD channels
The tuner is for Samsung plus TV. Not freeview uk. No. Bbc1,2,3 , itv, itv2 itv3 ch4 or ch5
Message 28 of 48
Re: HD channels
@Seany10hats
I think there's some confusion here.
Everything I've read indicate that it has Freeview (terrestrial TV) but not Freeview Play which is catchup built into the EPG.
TVPlus is an extra feature in addition to Freeview. My Panasonics have something similar but still have Freeview.
Message 29 of 48
Re: HD channels
I've just Googled it and it does have Freeview but not Freeview Play...
Message 30 of 48
Re: HD channels
My TV in front of me indicates it’s not there
