Message 11 of 14
Re: Hdr Apple tv
That clears that up then!
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 12 of 14
Re: Hdr Apple tv
Hopefully an update soon to support it ...I'm wondering if it's from apple tv end
Message 13 of 14
Re: Hdr Apple tv
@Tomjeffrey20
Must be; Apple write the app, the Pro box supports HDR.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 14 of 14
Re: Hdr Apple tv
Pro box doesnt support Dolby Vision though right, so the content on Apple that is mostly all DV will need to fall back to HDR10. Which is simple enough as Vision is a meta layer ontop of normal HDR I thought. Based on the description of the OP that it is tagged as DV in the app but doesnt present as such, seems the app is not ported for the EETV that well.
Content on Prime however ive found is nearly always HDR10, Netflix favours more Dolby Vision content also.
The above is my experience however with the equipment I use, Apple TV (Box) with those apps, I dont use EETV apps.
