Message 21 of 22
Re: Humax DTR-T1000 !HELP!
@badboydas
UHF aerial then. Just in case no-one’s taken down the VHF one.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 22 of 22
@redbridgefc
If you're still looking then there are some old Panasonic PVRs I'd recommend.
The HWT-150 is one I have and is rock solid and still decently quick and has the padding feature which has been one of the biggest gripes about Youview units since their introduction. The same applies to the HWT-130 & HWT-250.
They also don't have some of the annoying screen blocking features like when a new recording starts and when pausing/fast forwarding/rewinding. Plus you can't skip to another part of a recording by touching a number button on the remote by accident.
Manhattans are also quite well thought of.
