Message 1 of 6
IP mode picture quality.
Why is the picture quality so woeful in IP mode, especially disappointing for the HD channels such as BBC 1.and ITV 1?
If I switch over to my aerial, which is direct to the TV, the picture is much better.
I have plenty of internet speed and I'm connected via ethernet.
5 REPLIES 5
Message 2 of 6
Re: IP mode picture quality.
What resolution do you have the box set to?
Message 3 of 6
Is that the HDMI display? I have this set to UHD 50fps 10 bit. I've got an OLED TV.
Message 4 of 6
I have an oled also and the ip channels are the same as via aerial no difference in picture quality.
Message 5 of 6
Try 1080p and let your TV do the upscalling to 4K
Message 6 of 6
Thanks seems a little better. Bizarre why this is.
