Message 1 of 4
IP6007
my box has  stopped me from showing my subscribed channels. I can access my apps and MyBT player no problem. I have checked that my software is up to date and checked on my account with BT and it says the subscriptions are active.
Whenever i go on these channels it just says "cannot play channel please check if you can access this channel IPC6007" When you then click resolve it doesn't do anything.
Any Advice.
3 REPLIES 3
Message 2 of 4
Re: IP6007
Hi @TomWilliams and welcome to our community.
Sorry you're having a few problems. Can you just confirm how is the STB connected to the hub. Is it wireless, ethernet or adaptors?
Cheers
David
Message 3 of 4
Re: IP6007
Hi, I assume STB is the hub? its connected to the hub via ethernet
Message 4 of 4
Re: IP6007
HI @TomWilliams  - it looks like you still have this issue.
After selecting 'Resolve' and seeing nothing happen, if you select 'Close' on the page you're on you should see a message slate in the background which says something along the lines of "Press OK to set-up the channel". If you press OK on this message it should then resolve your issue.
The messaging is a bit poor here and is something we're looking at.
If you're still struggling to fix this please reach out to me and I will sort this for you.
Gavin
