Message 1 of 5
IPC6007, again….
Been away on holiday, left everything on. Returned and once again certain channels are no longer available. Have done the obvious - checked for software/app upgrades/box software version, switched off box, reset router, switched box on, left over night etc etc. starting to get really peeved with BT, for over £100 a month I expect better.
4 REPLIES 4
Message 2 of 5
Re: IPC6007, again….
Wife has lots of recordings, so a factory reset is not really an option, and lets be honest- should not be necessary.
Message 3 of 5
Hi @Chippers, sorry that you're BT TV box isn't working.
It is possible to do a reset without wiping recordings. Check out How do I reset my BT TV box? | BT Help
 and see if that helps and your recordings kept.
Cheers
John
Message 4 of 5
Cheers - thats sorted it for now…
Message 5 of 5
Hi @Chippers, thanks for the update and glad it worked and you were able to keep the recordings 🙂
Cheers
John
