Message 21 of 24
Re: IPC6023 error code
Which box as got 2
Message 22 of 24
@Cpl244
I think you mean “Which box, as I have got two?”
To which the answer is whichever one is set as your main box for EE TV.
if you have any recordings from EE TV (i.e. not terrestrial TV) this will be box on which these play.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 23 of 24
Hello, either box serial number would be fine. they will both be connected to your Hub and on the same broadband connection from your property to the exchange.
thanks
David
Message 24 of 24
Hi @Cpl244 as confirmed on DM, this issue should now be fixed and all services restored. Thanks for reporting!
