Message 1 of 24
IPC6023 error code
No live tv channels
23 REPLIES 23
Message 2 of 24
Re: IPC6023 error code
@Weddle1
Pro box?
Aerial or IP?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 24
The new EE Pro box
Streaming the tv guide channels through the Internet.
The apps work fine but blank screen
Anonymous
Not applicable
Message 4 of 24
I have had the same problem in the past, eventually I did a soft reset keeping any recordings, but in short term is to unplug power lead from back of the box plug it back in and that should work..
Anonymous
Not applicable
Message 5 of 24
Whatever setup you have doesn't seem to be passing multicast to the box.
Message 6 of 24
Tried all that it doesn't work the unplugging and restarting I mean
Message 7 of 24
What is multicast to the box?
Anonymous
Not applicable
Message 8 of 24
It's the network protocol that BT use to deliver channels via the EPG.
Message 9 of 24
Hi @Weddle1
Welcome and thanks for your post!
I am sorry you're seeing error IPC6023.  This error relates to Multicast which is the technology used to deliver the IP channels.  Can you post back and explain your home set up please?  Do you have the pro box wired direct into your Smart Hub?
Thanks,
Robbie
Message 10 of 24
So the pro box is wired direct to the hub.
The apps work fine on the box.
Like the Now app is working fine
But if I pick a Now channel off  the tv guide it shows the error code.
