Message 11 of 15
Re: IPC6023 when trying to view channels from guide, but work fine from the apps.
Before anything else, I recommend you replace the WAN cable (the red one they mentioned) - our systems show a fault on it, although I don't know why. You can use one of the cables that came with the TV Boxes, as you're not using them.
If that doesn't resolve it then the best I can suggest is that you call again, and allow a fault to be raised. To do this, you will need to follow all the steps they request - including allowing a box to be factory reset. Do NOT allow an engineer visit - insist that it's raised to TMC.
Message 12 of 15
Thanks.
I have tried with a different CAT6 cable.
My TV box has been factory reset 5 times, and every time I'm asked to do it I have to re setup everything and log into all my apps.
I'll call again tomorrow
Message 13 of 15
Just to check the obvious…just in case.
You’re using the BT Hub right?
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 14 of 15
Yeah. The Smart Hub 2
Message 15 of 15
After not receiving the replacement red cable, I escalated the issue.
My broadand connection was confirmed fine and that this could not be caused by the cable.
A replacement TV box was sent to me to rule out it being an issue with the box. Same issue with the replacement.
It has now been raised with a technical team and I am waiting a response.
Will update again once resolved
