Message 1 of 4
Ipc6007
Hi!
I’ve recently moved and have set up a new broadband hub. My by box is connected via adapters and I can use the apps such as NowTV fine. I am unable to watch any live tv through the guide and get a IPC6007 code.
I’ve tried unplugging the box several time but had no luck. C someone help please?
Tom
3 REPLIES 3
Message 2 of 4
Re: Ipc6007
@Yibi900
This Community offers:-
https://community.bt.com/t5/YouView-from-BT/IPC6007-again/td-p/2279019
where the suggested solution apparently worked,
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 4
Re: Ipc6007
Thanks for helping. Unfortunately this does not fix my issue.
Message 4 of 4
Re: Ipc6007
@Yibi900
Here’s BT’s take on this:-
https://www.bt.com/help/tv/what-do-the-bt-tv-error-codes-mean-
and type in IPC6007.
Other than that, Google the code, and see what strikes you.
There’s a suggestion the code means that BT TV don’t see your box as a valid BT TV subscriber, so you may have to involve the Admins on here.
