Message 1 of 3
Ipc6023 error.
I've rebooted both bt box and hub. I've done a factory reset. Bt box says I'm connected via ethenet (which I am). If I disconnect the ethernet cable the box reports loss of connection and reports its connected once the cable is restored. I can watch Netflix and other streaming services via the bt box but all my Internet channels are showing this error. Everything else connected to the hub works fine. Last time something similar happened (a couple of days before Christmas) it suddenly "fixed" itself on Christmas day!
Any ideas please. Getting fed up with not getting something I pay good money for.
2 REPLIES 2
Message 2 of 3
Re: Ipc6023 error.
Hi @johninblack
Thanks for your post and welcome back!
I am sorry you're seeing error IPC-6023 when trying to stream your Multicast channels.  We'll be able to investigate from here and put this right for you.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 3 of 3
Re: Ipc6023 error.
Panic over,  it's just started to work properly again.
Very strange.........
