Message 1 of 11
Ipc6023
Hi I'm getting Ipc6023  code on my s reen I've tried everything resetting box... using Etherley cable and wireless and I'm getting no TV all apps are working just no TV channels
10 REPLIES 10
Message 2 of 11
Ipc6023
Need help pleads got no channels  just apps I've reset box  I've tried ethernet and wireless and still nothing my main box works just not my multi room box
Message 3 of 11
Re: Ipc6023
Hi @Markpacitti
Welcome to the BT Community and thank you for posting!
I am sorry you're seeing IPC-6023 when trying to stream your subscription channels.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 4 of 11
Re: Ipc6023
Thanks for taking my call @Markpacitti .
Let me know how you get on connecting the box directly to the hub.
Cheers
David
Message 5 of 11
Re: Ipc6023
Hi David
No still the same I've also reset it again to factory settings and nothing the main TV box is full working just the little extra multi room box has totally gone off
Tags (1)
Message 6 of 11
Re: Ipc6023
If you're on FTTP, try switching off the ONT (the white box that the hub connects to) for 30 seconds or so.
Are you using a BT hub or a 3rd party one? The Eero hub for example doesn't use Multicast which is what IPC6023 refers to
Message 7 of 11
Re: Ipc6023
Hi les
The box was working since I've had it. It all just went off yesterday and can't get any channels apart from apps
Message 8 of 11
Re: Ipc6023
Try swapping the two boxes over, see if the fault moves with the box or stays with the location
Message 9 of 11
Re: Ipc6023
Swapped boxes... still the same it's the mini box that's not working
Message 10 of 11
Re: Ipc6023
Assuming that you are in contract, ring 0800 800 150 and report it as faulty, BT will replace it free of charge
