Message 1 of 7
Just upgraded bt tv. IPC6023 error
Hi all
I recently upgraded my Bt package incl BT TV. I installed the new youview bt tv pro box it all went smoothly to start with. I use an Ethernet cable to connect.
However the subscribed channels (entertainment+) don’t load and I get the ipc6023 error.  I restarted the box and disconnected the router and searched this error on this forum too but nothing seems to solve it
There is definitely no broadband  problem as the apps like bbc iplayer etc all load.
tia
6 REPLIES 6
Message 2 of 7
Re: Just upgraded bt tv. IPC6023 error
@hellothere19 I'm sorry to see you're getting the IPC6023 error after upgrading your BT TV package.
I'll send you a private message so you can get in touch with the moderation team and we'll be happy to help as it sounds like a subscription problem.
Neil
Message 3 of 7
@hellothere19
The other thing to try, if you haven't already done so ,  is rebooting the router. It may or may not work but worth a try.
Message 4 of 7
I did reboot but didn’t sort it.
Message 5 of 7
Hi Neil,
Message send
Message 6 of 7
BT called me back and I had to change the settings from FTTP to ASDL/copper which solved the problem and I have all channels now
Thanks for a quick reply in this matter
Message 7 of 7
@hellothere19 please can you confirm where the settings you needed to adjust were please? were they on the bt pro box or somewhere else?
