Message 1 of 5
Link bt remote to TCL TV.
I have just purchased a new TCL tv and have gone through the process to link the bt using the 3285 code but can not get it to link.
4 REPLIES 4
Message 2 of 5
Re: Link bt remote to TCL TV.
The Contour 4 Device One For All Universal Remote Control I use with my Cello TV has the following codes for TCL:  3779, 2715, 2675 and 2530
Maybe one of those will work with your set
Message 3 of 5
Thanks I’ll give them a try.
Message 4 of 5
Unfortunately they’ve not worked
Message 5 of 5
@Paulk1 It was worth a try
The All In One Contour remote range are not expensive if you want to avoid using multiple remotes.  You can set up to 4 different profiles for pro/mini boxes, dvd, blue ray players etc,  i got mine from Amazon, think it was around £12.00
