Message 1 of 11
U TV app not loading on BT YouView box
We have a BT YouView box.
The U TV app (U&Drama etc) is not loading. Other apps (BBC iplayer, Netflix) are loading successfully. The internet connection is fine.
We have tried a box reset. No change.
The YouView box software is up to date.
The box is a Humax DTRT2100.
Is there a service issue with U TV apps?
Any other suggested checks and fixes?
10 REPLIES 10
Message 2 of 11
Re: U TV app not loading on BT YouView box
Good morning @AE2023.
Welcome to the BT Community 😊
I've just given this a quick test at my end and I was definitely able to load the U app.
At what point does this seem to be failing, is it as soon as you load the app, or is it when trying to view a specific bit of content?
Also if you see any error codes, have you tried checking them here?
What do the EE TV error codes mean? | BT Help
Peter
Message 3 of 11
Hi.  I have been experiencing the same problem since Tuesday.  The U App on my tv was fine on Monday but since Tuesday it has refused to open, its opening screen either freezing or flashing.  There are no error codes.  I can watch U tv channels fine but cannot stream.  I have no problem with any other Apps - and the U App opens on my laptop.  UKTVplay has been unable to help even though it now seems that I'm not the only one!
Any suggestions gratefully received.
Message 4 of 11
Thanks for flagging this too, @Sunny13.
Which box is it you're using here?
If you're not 100% sure please feel free to post a pic 😊
Peter
Message 5 of 11
It's a BT YouView, I think.  Says BT 4K UHD on the front.
Message 6 of 11
Thanks for the swift response Peter.
The U TV app does not load to the homepage. We see the loading page (with the channel logos) for a few seconds. The screen then goes blank and then logo page returns. It seems to be stuck in loading.
we don’t get to the U TV app homepage…
Message 7 of 11
Thanks @AE2023 and @Sunny13.
I've fed this back to see if we've had any similar reports, but in the meantime have you tried doing a 'light reset' on your box as indicated in this guide?
How to reset your EE TV Box | TV and Sport Help | EE
This is a bit different to simply powering it on and off, but will allow you to keep your recordings.
Peter
Message 8 of 11
Thanks, Peter, (and fellow sufferer AE2023).  I don't appear to have a button on the right-hand side or front of the tv box, so unfortunately cannot follow light reset instructions.  (The U App is still not opening.)
Message 9 of 11
Thanks @AE2023, we have similar instructions for some of the older box models here:
How do I reset my EE TV box? | BT Help
Peter
Message 10 of 11
Many thanks, Peter.  My light reset appears to have solved the problem;  I can now open the U App.
Of course, I now have to activate all the other Apps as well but that's just a 21st century irritation!
Thanks again - a good first use of this community.
