Message 11 of 15
Re: Missing freeview channels
Yes, you will need an internet connection to the box (be it ethernet or wi-fi) in order to view the BT TV channels from channel 300 upwards
Message 12 of 15
Hi Les and everyone whose has responded to my post, thank you all so much for your help.  👌 Caroline
Message 13 of 15
Hi Neil, why are there no +1 channels available via TV Box Pro via internet? (I don't have a TV antenna)
Message 14 of 15
@St3v3M the list of channels available in internet mode is based on popularity and content rights. The +1 channels serve little purpose - especially with most content available in the catch up players.
Message 15 of 15
Understood, thanks DarrenDev 👍
Tags (1)
