Message 1 of 7
Multi Room
I currently have multi room in 3 additional rooms to my main box. There are no cables other than power and HDMI to TV on them. Dush cable and aerial to main TV are hidden in the wall. Can I have this set up with BT multi room (i.e 3 additional boxes wireless)
I don't want to have additional cables on view
6 REPLIES 6
Message 2 of 7
Re: Multi Room
Hi @PJM1966  I suggest that you have a look at or ask on the EE community
https://community.ee.co.uk/t5/TV/bd-p/TV
as although  EETV is still offered as a product by BT   they offer a reduced range of boxes and fewer multi  room boxes than EE themselves.
Anonymous
Not applicable
Message 3 of 7
Re: Multi Room
Note  that with BT/EE multi-room, there is no communication between the boxes. So you can't watch recordings from the main box on any other box.
Message 4 of 7
Re: Multi Room
So not like Sky in anyway then. ?
Message 5 of 7
Re: Multi Room
Not like Sky at all @PJM1966.  They're wireless, so no extra wires needed, but they cannot share recordings between them - they each work on their own to deliver all the channels and apps.  The multi-room boxes are unable to record themselves either.
You can have up to 3 boxes in total - your main box, plus 2 multi-room, when you order EE TV on EE Broadband.  There's no charge for the additional boxes.  On BT Broadband you can only order 1 multi-room box, and you need to pay for it (£10 / month last I checked).
Message 6 of 7
Re: Multi Room
Message 7 of 7
Re: Multi Room
If I understand correctly EE do now charge for  a second extra box  . Specifically their EE web site legal stuff says
EE TV Extra Box Offer:
Offer available to customers who have a 24-month EE broadband plan and 24-month EE TV plan. Offer allows customers to add 1 extra box to their EE TV plan at no extra cost. Extra box will be the Box Mini only. Broadband must have 30mbps minimum line speed and 50mbps for UHD content. Customers looking to take 2 extra boxes will only be charged for the second box. The price of the second box will be outlined in the price guide. More than one extra box requires 40mbps and 59mbps for UHD content. Offer to be redeemed in store, online or via our contact centre. This offer is subject to availability and can be withdrawn at any time. If you cancel your EE TV contract the offer will end. Service is for your personal, non-commercial use only and may not be suitable for under 18s.
