Message 1 of 8
Multicast Test Channel URL?
Evening all,
It’s been a while since I’ve had BT TV but I’m looking at coming back for the Now multicast integration.
Since last time I’ve upgraded my network setup, so before I pull the trigger or start playing with settings, I want to check multicast is working correctly.
The BT multicast preview channel url knocking around online looks to have changed and I can’t find any details of the current one.
The last one was;
rtp://234.81.130.4:5802
Does anyone know (or mind snooping through Wireshark) what the current url is?
Thanks so much,
D
7 REPLIES 7
Message 2 of 8
Re: Multicast Test Channel URL?
Anyone? 🙏
Message 3 of 8
Hi all,
Just wanted to come back and update this thread for anyone else looking for these streams to test their multicast setup.
I did a bit of snooping with Wireshark;
Britbox Barker
rtp://234.81.132.216:5802
Prime Video Barker
rtp://234.81.131.200:5802
BT Preview
rtp://234.81.131.194:5802
Hopefully it'll save someone else having to dig around for the current ones.
D
Anonymous
Not applicable
Message 4 of 8
@DaveSwan
Are there any tricks to using these in VLC? I can only find references to older versions of VLC that talk about enabling RTP. That option doesn't appear in the current version.
Message 5 of 8
VLC will just play them, you shouldn’t need to enable anything. Try this;
Aside from the BBC Sounds slide and barkers for Prime Video, Britbox and Netflix, everything is encrypted, so there’s nothing to see.
Anonymous
Not applicable
Message 6 of 8
Thanks, that's the URL I was trying. I just get a yellow bar sweeping across the bottom of the screen Knightrider style & no audio or video. AVM say the Fritzbox should pass IGMP but it doesn't seem like it is, so I'll see if they can offer more help.
Appreciate the post.
Message 7 of 8
No worries.
I had a similar situation of multicast packets not being sent out to both ethernet and wifi interfaces.
Spent ages trying to figure out why I could get the stream on iPad but not on the iMac - all it took was to unplug the ethernet.
Maybe worth a try?
Anonymous
Not applicable
Message 8 of 8
Thanks but doesn't work on either ethernet or WiFi.
Found a 3-year-old thread on Thinkbroadband about backing up the 7530 config file, hacking it & restoring. But that was for a different model (7390) & I'm not that brave! I'll report back what AVM say.
