Message 1 of 4
TV remote to control BT TV Box Pro
Is there a way to pair my TV (Panasonic) remote with the BT TV Box Pro? My TV remote controls the TV and Amazon Fire Stick just fine but it does not control the BT TV. It would be great to use one remote.
3 REPLIES 3
Message 2 of 4
Re: TV remote to control BT TV Box Pro
Hi @fikys and welcome to our community.
Take a look at Setting up your BT TV remote to control your TV  and let me know if that helps.
Cheers
David
Message 3 of 4
Thanks, David. I will try this when at home but this seems to make my BT remote to control my TV. I would like to find a way to do the opposite - my TV remote to control the BT Box. This is because my TV remote nicely controls the TV and Amazon Stick already. I don't know if the BT remote can control the Amazon Stick and it does not have the Netflix button my wife uses a lot :).
Message 4 of 4
I tried to follow the guideline but my TV Box Pro remote does not even have the buttons mentioned in the manual.
