Message 1 of 3
Netflix Error NW-3-6
Ever since BT have upgraded our TV box, we have had issues connecting to Netflix. The TV is connected to the Wi-Fi, with a full signal. However, Netlifx still states the error code “NW-3-6”. After a few tries of rebooting, retrying, turning both the Wi-Fi and TV on and off - then it does eventually work. But sometimes it simply won’t connect.
Has anyone else struggled with this error? And if so, how did you fix it?
Many thanks,
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Netflix Error NW-3-6
Hi @Langer1312
Are you using the NETFLIX app on the BT TV Box or  the TV’s own NETFLIX app .
Message 3 of 3
We are using the Netflix app on the BT box.
