Message 1 of 3
Netflix sign in query
I currently have a Netflix account. I know I should receive a link to activate Netflix via the BT box when I upgrade from Sport to VIP. The email address I use now for Netflix is different from the one I use to log into MyBT. Will this cause any issues or will the BT email link recognise the Netflix account anyway even though the email addresses are different? We have 3 Netflix profiles in the household and could do without the hassle of setting up new profiles and programme lists again 👍
2 REPLIES 2
Message 2 of 3
Re: Netflix sign in query
I had a similar issue earlier this week. The mods suggested logging into the app on the TV box with the account I wanted to use and that setup the bill through BT
Good luck
Message 3 of 3
Thank you @TheRealBudski  Sounds simple enough 😀
