Message 1 of 10
Netflix
Hello I am currently unable to access Netflix as it keeps coming up with error code nw-4-7 hasn’t happened before I’ve tried resetting everything Netflix say it’s a vpn problem but nothing seems to be working.
9 REPLIES 9
Message 2 of 10
Re: Netflix
According to NETFLIX own documentation
https://help.netflix.com/en/node/14560#
“If you experience the error code NW-4-7, it usually means there's information stored on your device that needs to be refreshed, or that there's a network connectivity issue. Follow the troubleshooting steps for your device below to resolve the issue.”  ( the link enables you to see their advice for the device you are using )
Message 3 of 10
Re: Netflix
Thanks for the reply
I’ve tried this already and I’ve contacted my isp which have said it’s a Netflix issue and Netflix have said it’s an internet vpn issue.
Message 4 of 10
Re: Netflix
So which device are you watching  on ?
Message 5 of 10
Re: Netflix
Mainly through my bt box.
Message 6 of 10
Re: Netflix
@ask1988 Do you have an active BT TV subscription or is it one you have retained from an old subscription? Or, is it a box that you have purchased via a third party retailer?
Do you have the model number?
Message 7 of 10
Re: Netflix
Yes active subscription. I feel it is a WiFi issue as it’s not working on any devices and my step daughter has her own account and that’s not working either.
Message 8 of 10
Re: Netflix
Ahh ok. I'd suggest trying the self help that @zulu17 recommended
Message 9 of 10
Re: Netflix
This problem is still occurring Bt have taken me through every step possible including resetting everything from bt box, modem, hub and have no sent me a new hub but it’s still happening.
Message 10 of 10
Re: Netflix
Check your network
く
✅Netflix server 1
❌Netflix server 2
nw-4-7
❌Netflix server 3
nw-4-7
✅Internet connection
Couldn't connect to Netflix. Please try again streaming device. For more information, visit
