Message 11 of 16
Re: New Pro Box pixillating and dropping
XAV5201
Thanks -
Message 12 of 16
Thanks - exactly as I suspected. It's the lower specification model, so is already running as fast as it can. A new cable isn't going to make a difference.
Message 13 of 16
I did ask helpdesk if I needed 2 cables. The Powerline is I think from December 2019 when I moved here and a new router was supplied.
Message 14 of 16
Would BT helpdesk provide new powerline boxes if what they send doesn't work or should I go to Amazon?
Message 15 of 16
Google says BT should provide new equipment if their current stuff is failing to work properly. So I will wait until this new cable comes and then if needed, which seems likely from what you have explained, go back to the Helpdesk.
Message 16 of 16
Yep, they should provide new adapters.
