Anonymous
Not applicable
Message 311 of 378
Re: New features
Finally got the new now and next vertical guide. Personally I like it, probably use it more than the full guide.
Message 312 of 378
Re: New features
Personally i prefer it how it was as you could scroll along the whole day without putting the guide on.
Anonymous
Not applicable
Message 313 of 378
Re: New features
How do you acquire the vertical bar please? (Assuming I have the software)
Message 314 of 378
Re: New features
@Anonymous are you sure you have the latest software? Might be worth forcing it. It should replace the old now/next function
Message 315 of 378
Re: New features
@DarrenDev  Thanks for the update. This is the main reason I am reticent to move over to IP delivery, along with a couple of missing channels n/a (Great Moves *)
Anonymous
Not applicable
Message 316 of 378
Re: New features
I think so.
I'm just wondering how (button presses) you acquire this new vertical menu. Or is it simply replacing the current EPG?
One thing of note. Since I changed to i.p mode. I'm getting for every recording of MasterChef a failed recording in standard BBC1.
I've tried cancelling the series record of the hd version tonight and setting it up again- see if it fixes it.
Message 317 of 378
Re: New features
@DarrenDev  @ozsat
 Thanks as always Darren. V useful.
One question, as I haven't changed to IP yet until the 2 channels recording issue is fixed,
is does changing to IP HD help with the problem with automatic  2.1 / 5.1 sound switching?
Message 318 of 378
Re: New features
No - there hasn't been any update on the audio channel tagging issue unfortunately. 😞
Message 319 of 378
Re: New features
Thank Darren.
Message 320 of 378
Re: New features
Were there some missing AR signals  today on Bt Sport 1 (HD but believe SD may had similar issue)  whereby   Scottish Football Extra  6;30pm  (to 7pm) appeared not to end until  7;59   ie the programme Premier League Review  that was being broadcast from 7pm to 8pm was not recognised as the current programme ?
