Message 21 of 38
Re: New progress bar is inferior
@pddco - that's a great tip for people to try.
I too was unhappy with the new progress bar, where it cycled through various forward/back speeds (up to 30x forward).
I have just soft reset my Pro box and the bluetooth handset now behaves as before.
I can confirm I also have 0.9.4
Message 22 of 38
I spoke too soon.
It has reverted to the 'new' method reported here 😐
Message 23 of 38
@neilg40  Hmmm.. Not sure what to suggest.  Perhaps worth reporting? Or indeed a hard reset (remove the power plug - wait 30 seconds - and plug back in).
Message 24 of 38
One of the mods said an update is on the way. In this thread I think
Anonymous
Not applicable
Message 25 of 38
@David_H
Just discovered another backward step with this update.
Previously when you paused live TV or a recording, the progress bar would disappear after a few seconds. So you could freeze to read a match stat or a program credit. The new bar is persistent on screen & never goes away, & so obscures the very thing you paused to read.
Message 26 of 38
If you pause a recording & press back the bar disappears
Anonymous
Not applicable
Message 27 of 38
So it does, thanks. But still literally a backward step IMO.
Message 28 of 38
@pddco - how/where do you report this?
Message 29 of 38
Hi @Anonymous and thanks for the mention. I'll add to the list for review, as we have some updates planned for early in the New Year.
Message 30 of 38
My box has been updated to s/w version: 0.9.58 and is much improved so thanks to those who raised this issue.
