Message 11 of 15
Re: Now TV Schedule Issues, Sky Sports NFL especially
Yes, I said that I gather they have a similar issue, I did mean that it was why I hadn't switched to Sky Glass instead, apologies for the misunderstanding.
Message 12 of 15
@MartinJSUK  I would suggest that you look to record tonights Monday Night Football on Sky Sports Main Event  or Channel 5 .
Message 13 of 15
That's perfect, thank you, good thinking. I can do Thursday Night's game that way too, though not the weekend, hopefully it will be resolved by then. Not sure whether to cancel the service visit.
Message 14 of 15
It is up to you - nothing you have described wrt to the NFL recordings suggests a box issue and there is clearly a problem with some of the data on  Now Sports EPG channel guides on BT TV if only someone in BT would bother to chase up the issue.
Message 15 of 15
I've cancelled the appointment. It's all rather frustrating, the ability to record these channels is one of the main reasons I upgraded (with a lengthy new contract) and it's very frustrating that it only works reliably for some channels. Potential customers need to be made aware that this is bordering on false advertising, nowhere is this issue mentioned.
