Message 31 of 60
Re: Picture Issues
OK @Tel2 so the other suggestion was to remove the cable and try WiFi.  Have you tried that?
Message 32 of 60
Re: Picture Issues
If EETV want to prove in these cases that it’s the customer’s WiFi at fault (WiFi usually from a BT/EE router, but let that pass) then they should perhaps have a service that provides for long enough Ethernet cables, returnable, to be sent out for affected customers to test with.
Problem then though, is either the pixelation will stop, over direct Ethernet, or it won’t.
Either way, then what? 😛
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 33 of 60
Re: Picture Issues
We're not talking Wifi here @Midnight_Voice - we're talking Powerline Adapters, which put it completely at the mercy of the internal wiring of the house (and every device that is connected to it).  If it were just Wifi, then BT/EE offer options for that.
Message 34 of 60
Re: Picture Issues
I have tested with ethernet & so have BT.
Tel
Message 35 of 60
Re: Picture Issues
My Broadband speed is c. 350,should be 500, & the TV screen Pixalates on every channel.
BT are sending me a new Router tomorrow.
Seams logical to me & ,again, thank you for your expertise which I NEVER ignore.
I will let you know if this is the solution.
Terry
Message 36 of 60
Re: Picture Issues
Even at a broadband speed of 44Mbps, you should still never see pixelation. A replacement router is unlikely to fix anything, but I have been proven wrong before. Good luck.
Message 37 of 60
Re: Picture Issues
Out of the blue BT has transferred my BT Account to EE & forgot the negotiated discount etc.
A young BT lady is dealing with the 24mnth. Contract & a Manager is ringing later this week about about the Monies due from the BT Swithing Team & my 2 Issues.
Terry
Message 38 of 60
Re: Picture Issues
Intrestingly, there are no Pixalation  Incidents on Recordings &/or iPlayer & ITV X.
The screen went black twice watching the One Show.
Tel
Message 39 of 60
Re: Picture Issues
@Tel2 Are you set up in aerial or IP mode?
Message 40 of 60
Re: Picture Issues
Ethernet.
Tel
