Message 1 of 13
Picture judder
Hi, I've noticed recently particularly when watching ITV the picture skips/judders every 10 seconds or so.
I've turned off frame rate matching to no effect.
Also, it occasionally reboots for no apparent reason.
Any ideas what could be the issue, faulty box maybe??
Thanks.
12 REPLIES 12
Message 2 of 13
Re: Picture judder
@freddie5
What’s the box?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 13
Re: Picture judder
Sorry, its a BT box pro.
Message 4 of 13
Re: Picture judder
@freddie5
Go to Settings/Factory Reset and do a Factory Reset (Keep Recordings).
This will ensure that your Box Pro’s software is how it should be.
It may not fix the issue, but should at least rule out a local Box fault as the cause.
Message 5 of 13
Re: Picture judder
Not yet tried a reset.
Paused TV this afternoon to make a cuppa, came back and pressed play, nothing happened when i pressed play just froze.
Had to power cycle the box to regain control but lost the ability to play paused program.
Im starting to think the box is faulty.
Message 6 of 13
Re: Picture judder
Now tried a factory reset, we'll see if that's sorted it.
Message 7 of 13
Re: Picture judder
I have a T4000. My recorded programmes also judder, like it has skipped a few frames every 10-20secs. It seems to get better sometimes later into the recording. I tend to use the skip forward at the start of the recording. Not sure if this makes it worse.
Message 8 of 13
Re: Picture judder
Hi @Ccy, welcome back to the Community.
Have you tried doing a reset on this like @Midnight_Voice recommended?
There are a couple of different options, including keeping your recordings, and you can find these details here:
How do I reset my EE TV box? | BT Help
Peter
Message 9 of 13
Re: Picture judder
Thanks Peter
resetting the box ( keeping recordings) seems to have worked.
Message 10 of 13
Re: Picture judder
Tried a factory reset, I think that may have sorted it, I was referring to live TV juddering, not recordings.
Seems now i'm suffering with the box rebooting whenever it feels like, normally when I'm actually watching something worth watching.
