Message 11 of 13
Re: Picture judder
As this has been after a factory reset and you don't mention how long it lasts for. I would look at the settings for power and standby and see if it's that as that can be set I think as little as 3 hours of as long as 12 after no input from the box. With the factory reset if you changed that setting in the past that would change back to default. Otherwise the timing seems very odd
Message 12 of 13
Re: Picture judder
Standby is set to 12 hours.
Does a reboot when it seems to feel like it, box has been on approx 4 hours now and just rebooted??
Message 13 of 13
Re: Picture judder
Thanks for checking that @freddie5
It may be time to have a word with our technical team to see if they can run some trouble shooting, as this doesn't sound like something we'd expect to be happening.
Lesley
