Message 11 of 19
Re: Pixelation on Film 4 channel 14
@SewS
It isn't the box that's dodgy, it's your TV signal. An 18% signal quality reading is dreadful.
A good quality signal would give readings like the ones quoted by @TimCurtis . In particular, the signal quality reading should be 100%.
Consider employing the services of an aerial specialist to sort out the problem with your aerial.
Anonymous
Not applicable
Message 12 of 19
You dont need a aerial to watch tv through a pro box.
You can stream content through your Internet connection.
Message 13 of 19
@Anonymous
Yes but not all channels and can't FF through ads on ITV to mention just 2 downsides.
Message 14 of 19
Yes. FF is what we’re after.
Looks like new box has sorted it after all.
Message 15 of 19
So far a new box has settled the issue.
Will keep in mind your suggestions for future issues.
Message 16 of 19
@SewS
Good to hear.
Out of interest check the quality & strength figures on channel 14 and 101 & 103 just to rule out any aerial issues and post back please.
Message 17 of 19
All three of those channels are showing 99% signal strength and 100% quality. Good enough for us !
Message 18 of 19
@SewS
Then that's the problem, your signal strength is way too high as that'll be overloading the tuners.
Get a variable attenuator (about £5-6),  connect between the aerial cable and the aerial input of the box and adjust until the strength drops to 85% ( as a start).
Message 19 of 19
Well well well…… that’s good to know.
Do you think the discs (we have two connected) will be adding to the overload?
Maybe (after the Euros) I’ll disconnect them both and check the signal strength…
