Message 1 of 2
Pro Box recording
When it says the box can record 2 or 4 channels in internet / aerial mode, does that mean it can record 2 programs simultaneously in addition to the one you are watching, or is the one you are watching included in the number?
1 REPLY 1
Message 2 of 2
Re: Pro Box recording
In IP mode - it can record two channels and you can view one of those.  Try to change to view a third channel and you have to cancel one recording.
