Message 1 of 2
Pro box
I have just received a Probox set up all OK. But when I switch it on the TV takes priority and I have to use the source button to activate youview.
1 REPLY 1
Message 2 of 2
Re: Pro box
This will either be a quirk of your TV or a setting that you need to change on the TV. Most tv's will turn on at the last input used. So, if you're watching terrestrial TV through the TV tuner, it will default to that when you turn it on. Why not use the Pro Box to watch TV rather than the TV tuner??
That's what we do, we don't even have an aerial connected to the TV.
