Message 1 of 3
Random failed recordings
last night my season scheduled recoding failed 10 minutes into Peston, for no reason I could find. This appears to happen way to often on the new internet only box. Is this a bug?
2 REPLIES 2
Message 2 of 3
Re: Random failed recordings
Hi @Caher, sorry you're having a problem with recordings. Have you tried a reset of the box with keeping recordings first (How do I reset my BT TV box? | BT Help) to see if that resolves the issue. If not then a factory reset would be the next option, after you had watched your recordings, and see if that resolves the fault.
cheers
John
Message 3 of 3
Thanks, I’ve done as you recommended and will monitor it.
