Message 1 of 5
Re: BT Pro box not connecting to the internet
I’ve got the same issue. Neither wired or wireless will connect.
4 REPLIES 4
Message 2 of 5
Hi @mabrookes and @blackthorn0001 and thanks for posting.
Are you using any adaptors or extenders? Can you give me a brief description of your set up?
Cheers
David
Message 3 of 5
WiFi is from Asus router, into open reach fibre wan connection. Wired connection is direct to same router.  Either would connect just fine up until the reskin update.
Message 4 of 5
Sorted - fresh direct cable temporally to the router - factory reset, and connected. Further Software update and the WiFi is working again.
Message 5 of 5
Thanks for getting back to us @blackthorn0001 .
It's great to hear you got this sorted. Thanks for sharing.
Cheers
David
