Message 11 of 19
Re: BT box keeps going into maintenance mode
will do, will report back.
Message 12 of 19
Hi @markgrant0
Please do and if you notice any adverse behaviour in the meantime post back as soon as happens and we'll assist from there.
Stuart
Message 13 of 19
@StuartH box appears to be fine, however its use has been very limited the last 10 or so days. Will keep an eye and report back. Due to limitations with available network connections ive had to move the cat5e back in to the switch and then the box connects to that switch.
Message 14 of 19
Hi @markgrant0, thanks for the update and I know you'll need to test it for longer to ensure the issue is resolved.
Cheers
John
Message 15 of 19
And it’s back, been a good run but as it was previously 🤦‍♂️
had to hard reset/pull the power every day since Saturday
Message 16 of 19
Thanks for getting back @markgrant0 .
Are you still connected via cable?
Cheers
David
Message 17 of 19
Yeah nothing has changed set up wise
Message 18 of 19
Thanks for the quick reply @markgrant0 .
We'll need to take a closer look at this so check your inbox for my message and drop me over the details.
Cheers
David
Message 19 of 19
thanks, replied now
