Message 11 of 26
Re: Keep Youview Box
I have a BT YOUVIEW BOX Zulu17. Nothing to do with EE. They just took over BT TV and that,s who a was paying (a think), as a just paid me last payment on 10th October, upgraded my Broadband with BT & Stopped the basic payment of £14.98 for TV prescription channels. Which in fact a should still be getting until 3rd November but they,ce already shut me down. But it,s not an EE BOX, BT YOUVIEW BIX a have pal
Message 12 of 26
Box a meant. But am receiving all my freeview channels (touch wood), no bother Zulu17
Message 13 of 26
It says BT in the middle & YOUVIEW at the bottom of the silver bit underneath on the very right hand side with C on Top off YOUVIEW over VI
Message 14 of 26
After literally smashing my brain to pieces reading through that lot, I’m glad Ive still got a satellite dish set up and all my Freeview channels just come through that without any naff boxes cluttering up my gaff! 😆
Message 15 of 26
@Kimberlin It is a confusion for customers of BT/EE own making as they have yet to come up with a properly communicated plan and process of managing the legacy EETV (formerly BTTV) boxes and legacy TV plans.
Message 16 of 26
Zulu17, to be honest a haven't been asked to return anything so far. But as you said it is a BT BOX with YOUVIEW written below on the silver bit at the very end of right hand side. Which has a C on Top of letter V. That s all I know, & getting all freeview channels over 50 actually.  See a got new Samsung 55 inch TV , bought it local from "EURONICS" maybe/probably spelt wrong. Plus wee guy came out & wired everything up. It even has it,s own stations which are quite good at times as well. That's about it, but your 100% about the box Zulu17.👍👍👍👍👍
Message 17 of 26
Even a decent rooftop aerial will get you most Freeview channels. Indeed, there are around 150 Freeview channels available.
Message 18 of 26
  • I am getting my freeview channels dear Kimberly no bother whatsoever. A was only saying am connected up through my internet. Which some people are finding this hard to believe. Plus as a said before a can also get. More 4. My 5. Iplayer,  plenty more & New Samsung channels. That was all. As we're I am situated in N.Ireland often get Virgin from Republic of Ireland. And yes, maybe in the Spring time next year a probably will get a new Aerial installed.👍👍👍👍👍👍👍
Message 19 of 26
Youview TV Box
Do you have to send your Box back for them to DISMANTLE , sure that,s MADNESS. Why will/don,t they sell it to you??????
Anonymous
Not applicable
Message 20 of 26
Re: Youview TV Box
  • Some might say pvr's in a streaming age is madness.
To answer your question
No they won't sell it to you
You could not return it and pay non return charge
(£140 pro box, older models are not so expensive)
but not sure if that cause of action effects your credit score
You could just buy a new one from Ebay for around £100
Also if you obtained your box before Dec 2019 it's yours to keep anyway
