Message 21 of 26
Re: Youview TV Box
Yea, a think a got that one 2022 0r 23, so as you said if they looking £140, be safer just buying one, or maybe just pay the £140 as got/have a 2024 New 55 inch Samsung Smart TV and who a bought it off almost a year ago now, has everything well wired up here for me as a have no Aerial etc. See what nhappens as a know a guy works or used to for BT and he,ll know the crack what a should do. Thanks again.
Message 22 of 26
Re: Youview TV Box
@rodders241
Bit confused here, you’ve started up yet another thread about Youview TV boxes when you could have just continued with your previous thread?
https://community.bt.com/t5/EE-TV-YouView/Re-Keep-Youview-Box/td-p/2447038
Message 23 of 26
Re: Youview TV Box
Without an aerial keeping the Youview box will be pointless. You won't be able to access, or record, any channels, streaming or over the air. The only thing you'll be able to view are the apps. In that case just buy yourself a Firestick in Amazon's Black Friday Sale and save yourself money.
Message 24 of 26
Re: Youview TV Box
A have one, I  don,t no what why you,s work over in England but I,m getting loads of channels plus a could of bought a YOUVIEW BOX there today as there going for in around £50 on Ebay, any amount of them, with cable and remote included folks!
Message 25 of 26
Re: Youview TV Box
@rodders241
Let's be very clear here that without an aerial and without a BT/EE TV subscription then  NO Youview box is of any use to you.
It's only the Pro box that gets the Freeview (BBC1 etc)  channels over the internet and that only happens with a current TV subscription. The earlier boxes had no such facility.
Message 26 of 26
Re: Youview TV Box
You've already posted you don't have an aerial, then you say you have. Just for clarity how do you receive the DTT channels then?
