Message 1 of 9
Rebooting new Pro box
Had new Bt pro box installed recently and set to IP mode however I have to reset it every other day. It keeps saying internet connection issue but I still have Wi-Fi through the house. Rebooting router has no effect only rebooting Probox works.
any ideas?
cheers MKC101
8 REPLIES 8
Message 2 of 9
Re: Rebooting new Pro box
Hi @MKC101, sorry that this is happening with your TV package. If you're using powerline adapters have you tried resetting them?
Cheers
John
Message 3 of 9
I’m not using power line adapters it’s happened again the error code is IPC6002 check connection between box and router.
connection is fine though
Message 4 of 9
@MKC101 is the Pro box connected to the your Smart Hub via Wifi or ethernet cable?
Neil
Message 5 of 9
Ethernet cable
Message 6 of 9
@MKC101 do you have a spare Ethernet cable you could try?
Neil
Message 7 of 9
Thanks but that was of first things I tried. Also switch ports on router but no change
Message 8 of 9
Thanks for confirmin that @MKC101 . This sounds like we ned to get our specialists to take a look.
I've sent you a private message so drop me over the details and we'll take it from there.
Cheers
David
Message 9 of 9
Hi @MKC101
Just a quick update for the benefit of the community. I can see the engineer confirmed the box was faulty and replaced it for you which solved the problem. Post again if you have any other problems.
All the best
David
