Message 1 of 2
Recording series problem
Record series does not work for Channel 82, although other channels seem OK. For 82, only the next episode is recorded.
1 REPLY 1
Message 2 of 2
Re: Recording series problem
Hi @ap10-27,
Thank you for posting and welcome to the Community.
If the series recording feature is not working properly for a specific channel, such as Channel 82, it could be because of missing program information.
It's possible that the program information is not being transmitted correctly or is missing. Unfortunately, this is something that is controlled by the broadcaster, and there isn't much you can do on your end to resolve it.
Thanks,
Paddy
