Message 1 of 2
Second box multiroom
I’m just in the process of moving my tv package from Sky to BT. I have ordered a second box as I wish to watch tv in another room.
However, as it is not possible either to either record or view recordings on the second box, I’m wondering whether to delete that from the order as I have an Amazon fire stick. I believe if I have taken the Now entertainment package I can still access this independently of the BT box, so could access this along with BBC iPlayer, Netflix etc through the fire stick. Is there anything I’m missing to make it worthwhile to continue with the order of the second box?
1 REPLY 1
Message 2 of 2
Re: Second box multiroom
The 2nd box acts as another device to watch your TV subscription and Freeview, if you have another means to do that, then you can go that route, do what works best for you.
