Message 1 of 3
Series recording
Series Record not working on channel 4 for FOUR IN A BED. Series record intermittently not working on BBC1 for Eastenders.
2 REPLIES 2
Message 2 of 3
Re: Series recording
Typically this would be data driven based upon the broadcaster data supplied for the  Youview EPG matching the broadcast programming.  Issues can also occur if for whatever reason your Youview box does not wake-up to do the recordings.
I think the latest series of Four in a Bed started in mid April did you set up your recordings then and did you get any recordings succeed ?
Message 3 of 3
Single recordings worked. Series recordings did not. Rebooted the YouView box and looks like series recording is working again.
