Message 11 of 12
Re: Source and More on BTTV Pro box remote
@scoopuk are all of your remotes the last one here, or do you have a mixture?
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have
Only the last one is bluetooth and self-configuring for direct-to-tv functions, the others need to be configured manually
Message 12 of 12
All three are of the last one, specifically for the BT TV vision pro box. All the remote functions work except for Input Select.
