Message 1 of 19
Sports Channels all gone!
Today the guide was empty so I did a reset to get it all back. It came back but now there’s no sports channels!! I knew that BT Sports was moving to Discovery+, but I though that was just the app. Is this applying to Sports channels on the box as well? If so I am not happy as now we cannot record anything. Plus also the Sky channels have gone as well, and I didn’t think those were supposed to be affected by the change. What is going on please?
18 REPLIES 18
Anonymous
Not applicable
Message 2 of 19
Re: Sports Channels all gone!
That doesn’t sound right, having reset the box, have you restarted your hub?
Message 3 of 19
BT Sports were rebranded to TNT Sports, so your subscription is the same, just a different name.
The BT/TNT Sports app is closing, instead customers are to use the Discovery+ app, again same content just a different app.
If you have no channels then it's not caused by the recent changes, possibly a fault, ring BT and ask for help.
Message 4 of 19
No, I didn’t do that. I will try it and see what happens. If that doesn’t work I’ll have to call BT (😟) as Richie has suggested.
Thanks for the replies, BTW. Much appreciated. 👍
Message 5 of 19
@alexmidd that's not good, are you getting an error message or code?
Neil
Message 6 of 19
No, they’re just not in the list and the SPORTS category has disappeared from the banner at the top.
Message 7 of 19
@alexmidd if you tap in channel 408 on the remote does it bring you to TNT Sports 1?
Neil
Message 8 of 19
It says “No Channel”
Message 9 of 19
@alexmidd Try channel 330 which will tell us if the box has a connection to the Internet.
Message 10 of 19
Oh well, it looks like it’s knackered now. I did a factory reset and now it doesn’t recognise the remote at all. One now useless box! 😢
