Message 1 of 4
Subscription channels (Now) not showing on EPG on Pro Box
Hi
I’m back (it’s been many years with the dark (sky) side, but back with BT now).
Can I have some help from the mods please.
Set up pro box yesterday (nice piece of kit), I have a Now subscription through BT which is signed in and available through the app but channels are now showing on the epg.
I have reset the box and tried to update the software which is stating that it is up to date, but still no luck.
Some assistance would be appreciated.
As always thank you in advance
Regards
Sharken
3 REPLIES 3
Message 2 of 4
Re: Subscription channels (Now) not showing on EPG on Pro Box
Hi @Sharken welcome back, I'm sorry the channels are not showing on your EPG and thanks for trying those checks. We'll need to raise a fault for that issue and I'll send you a private message so you can send your details to the moderation team and we'll be happy to help.
Neil
Message 3 of 4
Thank Neil
I have replied to you pm
Many thanks
Mike
Message 4 of 4
Hi @Sharken, thanks for getting in touch and good to know that this is now fixed for you.
Cheers
John
