Message 1 of 5
Switching tv options
I've been on a legacy tv package for years, which finally went out of contract on the last bill. BT sent an offer to upgrade from Entertainment Lite to the Entertainment Plus, but I cannot switch to this service. I've tried the app, the website, spent a long time on the phone, only to find the assistant couldn't upgrade me either and couldn't figure out why. Her only suggestion was cancelling everything and switching to EE for broadband and tv, which seemed a bit ridiculous. I can add sport, or boost, but the system just won't let me switch the main packlage. Anyone got any ideas?
4 REPLIES 4
Message 2 of 5
Re: Switching tv options
When was this call @w2pixel?
Your account notes show a call 2 days ago, where you were advised to call again after your current order had completed, where it should be possible to add TV (and upgrade your broadband at no additional charge). I don't see any calls since though?
Message 3 of 5
I tried again online, but hadn't called, as nothing seemed to have changed and didn't want to waste time on having the same thing happen. I did winder if it was my old sky cinema add on that was causing a conflict. It's been cancelled, but my account says I have access to it until my next bill on DEC 2.
Message 4 of 5
That shouldn't cause any issues, but I can't say for sure as I know the NOW integration has been quite troublesome lately.  If it doesn't work, ask them to raise it as a fault rather than just get you to call back again.
Message 5 of 5
Thanks, they've escalated it, and said hopefully by next Monday I should be able to switch as they still couldn't figure out the issue
