Message 31 of 70
Re: T4000 Fault causing Power-Down ...
no i have not as yet , if it carries on i will do it next week thanks
Message 32 of 70
No problem @welshgit
Let us know how you get on 🙂
Leanne.
Message 33 of 70
Surely its the same problem as Darren Dev Id'ed - ie COM5 Channels like Film4+1 & QUEST+1  ....
"I've spoken to a specialist today and we're currently investigating an issue only affecting DTT channels on COM 5 - skipping over ad breaks with adverts that are broadcast in mono can sometimes cause the box to crash and reboot.  Does that match your experience?  i.e. were you watching any of those channels?"
Message 34 of 70
not just ad break skip it does it if i skip in the middle of a programme too . i reset the box for the 2nd time and at the moment it seems to be ok so far
Message 35 of 70
Thanks for the update @welshgit
Fingers crossed it's now sorted for you 🙂
Leanne.
Message 36 of 70
no made little difference still shutting down and rebooting after pressing skip forward , a phone call will be needed me thinks
Message 37 of 70
Hi @welshgit
Thanks for updating us 🙂
Please let us know how you get on after calling.
Leanne.
Message 38 of 70
a replacement t4000 is on its way, but to be perfectly honest i don’t think it will make much difference as i think its a software issue and once the replacement updates the corrupt software will re-appear ...or am i being pessimistic
Message 39 of 70
Agreed - it's likely to be the issue already mentioned. A fix will be made available as soon as possible.
Message 40 of 70
This is also happening to me on two boxes, the older recently died with a hard disk failure, but was suffering from total crashes when fast forwarding through a recording. Powering up via the the remote shows BT logo and you-view screens, same as a mains power on. I've only noticed this happening within the last month or so.
BT sent me a replacement T4000, which I then manged to cause the same crash shortly after going through the initial setup with the replacement box.
