Message 11 of 13
Re: TV stuck on channel
It sounds like the box is in a bad state then.  Can I ask you to please try a maintenance mode reset as follows:
  1. Turn the power off and then on using the switch found on the back of your box. A red light should appear on the front.
  2. Press and hold the down arrow button on the top of the box for 5 seconds until you see Enter Maintenance Mode Y/N (Y:POWER) prompt. The box light will turn blue.
  3. Press the YouView button on the top of the box.
  4. The box should now enter maintenance mode.
  5. Choose your preferred option and follow the on screen instructions.
The "keep recordings" option first (if you have recordings you want to keep).  If that still doesn't help then try "delete recordings".
If that doesn't help then it's likely that the hardware has failed.  If you still have an EE TV subscription then give us a call and we'll replace it.
Message 12 of 13
Hi Darren, thanks for the reply i have tried those steps but i can even get it into maintenance mode.
Can you have a new one sent out?
Mark
Message 13 of 13
Unfortunately I'm not able to do that @mark74 - you'll need to contact us using one of the options here: https://www.bt.com/help/contact-bt/technical-support/tv
