Message 1 of 3
The Apps on my BT YouView box don't seem to be working - i.e. no iPlayer. no UKTVplay
I notice a couple of days ago that my BT YouView box is not receive UKTVplay, it shows 'Loading' then reverts to whatever it was doing.
Has something changed?
MB
2 REPLIES 2
Message 2 of 3
Re: The Apps on my BT YouView box don't seem to be working - i.e. no iPlayer. no UKTVplay
Hi @JMB,
Can you check out @zulu17's post here Re: Apps and let me know if it helps you?
DanielS
Message 3 of 3
Tried all that as replied in the other thread.
Done a Factory Reset now and all seems OK.
Thanks for the help.
MB
