Message 1 of 8
Why am I getting a message saying I have a problem with my broadband when watching subscription chan
Watching BBC HD ,no problem,but unable to watch my subscription channels IPC6023
Looks like I will be cancelling BT TV BIG SPORTS.
7 REPLIES 7
Message 2 of 8
Re: Why am I getting a message saying I have a problem with my broadband when watching subscription
have you tried the mod suggestions here
Solved: IPC6023 - BT Community
Message 3 of 8
Yes,each time it works again eventually, able to watch Sports Main event now but for how long?
Message 4 of 8
Gone again IPC6023 back to BBC HD!
Message 5 of 8
Oh well, looks like I will have to cancel!
Message 6 of 8
Hi @Filosopher and thanks for posting.
Sorry you're having problems with the IPC error message. It sounds like you've done everything possible at your side so I'd like to take a closer look at this for you. I'll need a few details so I'll drop you over a private message now so you can get in touch.
Cheers
David
Message 7 of 8
Try changing your ethernet cable. Our Pro Box randomly started dropping it's connection to the hub and a simple cable swap solved it.
Message 8 of 8
I don't use an ethernet cable...WiFi. Got technical help last night. Channels restored until conversation ended. This morning all working and another offer of help from David if the problem reoccurs.
