Message 1 of 3
now tv through BT
I can watch now tv through my bt box, but the moment i try to watch via another device, like it says i can, nothing works. However, it says that i can't as they don't recognise my email address, and it's the only address that i have and use. Please help
2 REPLIES 2
Message 2 of 3
Re: now tv through BT
Does it not say which e-mail address to use on the activation email you received from BT? If not try using your BT ID
Message 3 of 3
If you login to your bt account. Under Now TV you should able to manage your subscription and change your password via that.
This should help you login to the app.
I have used this method before
